Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Tee - Errors When On Pipe Run
2 REPLIES 2
Hugh_Compton
420 Views, 2 Replies
I have created my own custom Tee Pipe Fitting.  When I try to convert an elbow on a pipe run to this tee (using the small + symbols) it throws an error.  I'm sure I have done something simple incorrectly...
2 REPLIES 2
CoreyDaun
in reply to: Hugh_Compton
Can you use the fitting in the project normally, meaning drawing a pipe tee rather that using the "+" icon? I think the problem here lies in the Family's geometry; in the Family Editor, I tried changing the value of "d" and it returned a whole slew of constraint issues which results in deleted extrusions. This is likely causing the error in the Project, since the Connectors' hosts are being deleted.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Hugh_Compton
in reply to: CoreyDaun
Still not really understood this one but the fitting works now...
I redid the 'body' that was defined by parameter 'd' by using sweeps instead of extrusions with no joy.
I then removed the nested family (that defined the socket) and made the sockets as blends.  This then worked.....odd since I have used nested families without any problems on other fittings....
Thanks CADastrophe for pointing out that there was a modelling error somewhere causing the problems.....
