does anyone knows how to make a tandem circuit breaker in a panel schedule in revit mep 2012?
Welcome to the Discussion Groups!
There is no direct way to do this currently, but there is likely a relatively simple work-around. How do you indicate such a breaker on your typical drawings? Do you indicate this on both plan and on the panel schedule?
Try checknig out various cutler hammer circuit breakers that are miniature or westinghouse. If you truly need tandem or triplex, quad breakers then visit eaton to get more information regarding poles, amps & family depending on which part you need. Try to find the right datasheet too.
Gabriel, did you ever find the way to create a tandem circuit breaker in a panel schedule in revit mep????
Thank you.
AFAIK, Revit does not have this option.
Fábio Sato
