I have a computer in my office that takes 5 times longer (25 min.) to open a Revit MEP 2012 project than any other computer opening the same file (under 5 min.). All computers have roughly the same specs. Everything else on this computer seems to run fine. Any help would be appreciated.
Make sure the Revit on that computer has the latest update (quite sure it is Update 2). Do you run any add-ons or Beta programs?
I am finding out that running any other program while running REVIT slows it down. While running REVIT I have every other program closed including e-mail. While opening make sure every thing else is closed first & see if that helps.
Thanks everyone for your input. The problem was with a network switch that was connected to the computer, I disconnected the switch and the files opened in under 5 min. So all is well in the world of Revit again. Thanks again.
