Revit MEP Forum
Tagging Mechanical Equipment
2 REPLIES 2
test_52
1795 Views, 2 Replies
Is it possible to have a tag for Mechanical Equipment show the location of the equipment based on the Space Name and Number. For example, I would like to create a Concrete Pad Schedule that lists the room name and number where the pad is located along with the dimensions of the pad.
Is this possible?
2 REPLIES 2
dennis
in reply to: test_52
Short answer on the tag part, "Not that I know of".  But you can in a schedule.  Create a Mechanical Equipment schedule, then on the Fields tab of the Schedule Properties dialog, lower left, you will see "Select available fields from: " and it is probably pointed to Mechanical Equipment.  Click there and select Space.  Then you can add Space info that the equipement resides within.  When you make your concrete pads, they will need to be classified as Mechanical Equipment.
test_52
in reply to: dennis
Thanks a ton. That worked perfectly!
