Hi, is there a way to instruct Revit to disable leaders in tags by default? Ideally on a per family basis?
(but I did not find that feature in the family editor with a tag open... )
I am turning off leaders most of the time and would really prefer tags come in with no leader...
Workarounds?
Feature request if not possible?
Solved by MuirEng. Go to Solution.
I believe it is still a per session setting. As soon as you select a tagging option and you deselect the leader option, it will keep that setting during the whole Revit session.
So one time deselecting during a revit session does not seem a major timewaster to me.
Thus a setting for all tags not differentiated by tag category etc and reset after restarting Revit
Louis
Please mention Revit version, especially when uploading Revit files.
aha, I didn't spot that control. Thanks!
