I am creating a template in Revit MEP 2012, we are using System Types to create all of our Pipe systems for Plumbing and Fire Protection.
my question is, can I add System types to better organize my template families and types etc.
it seems I am limited to the following
Hydronic Supply, Hydronic Return,Sanitary, Vent, Domestic hot & cold Water, and Other
I would like to be able to sort them based on use
example: Lab, Medical, Air, Filtered Water, Pressure Control, Special Tempreature.
Is this possible without breaking into the API?
thank you
Solved by abulla. Go to Solution.
Yes you can. Go to view tab----user interface------system browser-----select any pipe system---------right click-------select properties------duplicate the system.
Thank you for your response.
I made a mistake in my question. I want to be able to change the System Classification
I have attached an example for clarification.
The System Classification is not editable
I would like to create a system Classification for Non Domestic Cold Water
thank you
thayt is what I will end up doing
hopefully this is something they can improve for later versions
