We are currently working on electrical connections in Revit 2013. At the moment we have a large piece of equipment mounted on the ceiling, and a receptacle in the same vertical space, about 4' below. However, it is impossible to see the receptacle because the equipment masks it. Is there a way to show the receptacle symbol on top of the equipment without changing its actual elevation?
Solved by abulla. Go to Solution.
