My HVAC model shows in 3d, but the structural model does not show. I really need to see the beams in 3d to cross check my duct layout vs. beams.
I have checked the detail level and tried different settings and I have played with the VG settings. I can see the beams clearly in section view, but in 3D they are flat.
Screen shot attached.
Thanks for the help!
1st... Assuming the at the Structural file is Linked, have you checked the VG settings for the "Linked" File?
2nd.....Are you using a "TEMPLATE" for the view.......if so, check the VG setting in the TEMPLATE SETTINGS for the Linked.
HTH
M
