Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
storm pipe fittings
1 REPLY 1
lroeber
178 Views, 1 Reply
storm pipe fittings
I am having problems connecting sloped storm piping, or just sloped piping in general? and good tips or suggestions. or does any body have any storm pipe fittings?
thanks
1 REPLY 1
in reply to: lroeber
If you are using Revit MEP 2009 select the fitting, right click to draw pipe, on the options bar set the slope and drag away the direction needed and click. You can also create a section offset slightly from the fitting and draw in section if needed using slope setting in the option bars.
This is a good way to stub out the pipe from the fitting and then extend the pipe from that point. Then use a little auto routing if you dare.
David
