There are lots of standard details already in AutoCad. My understanding is, the best way to use them is to create a drafting view in Revit and then either link or import the stardard details over from AutoCad.
But, what would it take to create standard details in Revit? I don't think I would want to use actual families of real components, because it would be way too difficult and time consuming to create all of those families and assemble them into the standard details. What would be the best way to assemble a library of standard details in Revit?
you have heard correctly.
when you want to use the details in a project do the following
hope this helps
Sounds messy! I guess it takes quite a long time to get the line thicknesses correct so that the details look good.
Drafting Views are ideal, but we ran into the issue of not being able to crop Drafting Views. Most of our details are contained in the same CAD file and we didn't have the time to break them up and link in each file in to a dedicated Drafting View.
What I ended up doing was creating a new Floor Plan view and turning off all Model AND Annotation Categories. Then I Linked in our 'master' CAD file with the option "This View Only". This allowed us to create Dependent Views and subsequently make use of crop regions.
I've converted a small number of details, and a couple of them I began by linking in the CAD file and then exploding it.
What if you used one drafting view for each individual stadard detail? That way you would insert them individually onto the sheet and be able to arrange them any way you like.
Yep. Then you can reuse them as needed as described in bwright's response.
bwright wrote:when you want to use the details in a project do the following
- open project you are working on
- goto insert tab > import panel > select insert from file
- choose your details project file
- choose the details you wish to use for your project in dialog box
- voila a clean revit detail
That's how I've started setting them up as well - the 'Dependent View' method was purely due to time constraints.
Hi, i do the same thing. but when i insert details views from my library file it doubles families, for the same type i got tow copies. for example: (interior metal stud 91mm) and ( Interior metal stud 91mm2). it creats a copy and adds (2) after each type. can sombody helps please. Thanks
