Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Stack Number
1 REPLY 1
419 Views, 1 Reply
Stack Number
Hi
I need to have some sort of identity data for my stack so I can tag it and the label in the tag would automatically read the stack number.
I tried Comment and Description but they are not working.
Right now I am using the Mark value, but it doesn’t feel right as it changes every time I connect a branch to the stack and brake it.
Any tip?
1 REPLY 1
CoreyDaun
Hello, welcome to the Discussion Groups!
You should be able to use the Comments or Description Parameters. Have you edited the Tag Family and modified the Label to report the appropriate Parameter? If you would like a better explanation, don't hesitate to ask!
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
