Hi
I need to have some sort of identity data for my stack so I can tag it and the label in the tag would automatically read the stack number.
I tried Comment and Description but they are not working.
Right now I am using the Mark value, but it doesn’t feel right as it changes every time I connect a branch to the stack and brake it.
Any tip?
Solved by CoreyDaun. Go to Solution.
Hello, welcome to the Discussion Groups!
You should be able to use the Comments or Description Parameters. Have you edited the Tag Family and modified the Label to report the appropriate Parameter? If you would like a better explanation, don't hesitate to ask!
