Revit MEP Forum
Splitting ducts without using unions
8 REPLIES 8
Message 1 of 9
Mehdi.Kardehi
2413 Views, 8 Replies
Hi all,
When I split a straight duct Revit by defauls adds a union. I would lilke to split the duct into duct pieces but with no union. Actually what I want is two ducts being connected by flanges.
8 REPLIES 8
Message 2 of 9
bvm76
in reply to: Mehdi.Kardehi
What you can do is to duplicate the union and edit it so it looks like a flange then add this into the duct routing preferences (as attached).
Please mark Accept as Solution if your question is answered!
Thank You.
Message 3 of 9
Mehdi.Kardehi
in reply to: bvm76
Thanks mate...
I am having a problem here....I am trying to follow your instruction
I want my flange thickness to be at 38 mm and what I did I added 8 reference planes and an extrusion to show the flange...
What i did next was loading it to the main project and going to duct routing preference and changing the union to the flange I just made
Unfortunately the result is not the same as yours...my flange and air ways size change!....family is attached. Can you please tell me what am I doing wrong?
Message 4 of 9
Apart from that I would really like my section view of the duct to look like this...
If not possible I will stick to your method and add detail drawings for this purpose
Any help is greatly appreciated
Message 5 of 9
bvm76
What happened to your flange family was the internal dimension (which is the duct width & height) are constraint to reference plane which are not dimensioned. See attached.
I'm working on the additional bolt. I will let you when I'm done.
Thank You.
Message 6 of 9
bvm76
Here you go.
You can amend the bolt dimensions to suit your requirements.
Thank You.
Message 7 of 9
Mehdi.Kardehi
in reply to: bvm76
thank you very much...i was trying to find  a solution for this for ages
Message 8 of 9
Mehdi.Kardehi
in reply to: bvm76
can you think of a way that flange becomes part of the duct not a seperate fitting...as you know in reality this is the case
Message 9 of 9
bvm76
No since Ducts are system families which are not editable.
Thank You.
Rail Community
