Can I configure the Split command to add appropriate connection fittings when splitting pipe. Like for instance a socket welded pipe coupling in a copper hot water system?
Can this be configured to know what system is being split and add applicable fittings... like victaulic, or flanged 150 lbs fittings?
Where do you go in the software to do this?
