Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Specific Duct Fittings in Revit
2 REPLIES 2
520 Views, 2 Replies
So Revit is gret at making automatic duct fittings. Is it possible to get it to make something like this:
Would I have to make a family for it? or is there somewhere that oyu can download common fittings such as this?
2 REPLIES 2
CoreyDaun
If you're talking about a specific offset transition fitting, the OOTB Family covers that, as will most manufactuer's Families. Revit will automatically create such a fitting if two Ducts have the correct justification and are aligned on one side, instead of on center. Create both Ducts, select one segment, and use the grip to drag and connect it to the other, and the offset transition should be automatically created. See attached image.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
iamwhatiam1234
in reply to: CoreyDaun
HOW TO CHANGE THE CONTROL POINT FROM ONE SIDE TO ANOTHER SIDE?
