Has anybody figured out a way to either turn off or make unselectable the Spaces, but still display the Space Tags?
Solved by CoreyDaun. Go to Solution.
If a Tag's host becomes hidden, so does the Tag. This means that you cannot hide the Spaces and still show the Space Tags.
Here are three possible methods, none of which are perfect.
#1 - Tag the Room the Linked Model
This is what we do here. Use Room Tags (you can easily steal the Room Tag Family from a lined model) and Tag the Rooms through the Linked Model. You can leave the Spaces turned off and the Rooms from the Link shouldn't get in your way when working on MEP design.
#2 - Dedicated Workset
This will only work if Worksharing is enabled and you check-out Worksets. Create a specific Workset for the Spaces and ensure that it remains uneditable. Check the box towards the bottom right "Editable Only". The major annoyance to this method is that by pressing ESC when no commands are active or no object are selected will cause this option to revert back to default.
#3 - Overlapping Viewports
This is the most convoluted method and requires you to work from the Sheet Views via 'Activate View'. If you create a separate View for Spaces and Tags only, you can overlay that Viewport on top of the actual Floor Plan, then use EH (hide element) to make it unselectable (it will still print). If you then activate the Floor Plan View, you can see the Space Tags but cannot select them.
This is tested in Revit MEP 2013. Don't hesitate to ask if you have any questions!
Thank you for the ideas. I think we will probably stick with just turning othem off and on as needed, unless somebody else has other thoughts.
Dustin
I've been working with spaces for over 3 years. The best way to do this is to have a modeling view and a documentation view. Put your spaces tags and other annotations that you want in here for reference. Then, on the documenation view these are turned off.
Also, you can create a space schedule and reference the architectural rooms and export an excel spreadsheet to compare.
-Josh F
