So I just got a file from an architect and linked it into our template and I having issues getting the spaces to wrap around the roofs. While testing I created a new file from a Mechanical Template and it worked fine. I then copied the walls/roofs and it didn't work. I created another file from a Construction Template and it didn't work!
See the image attached. Exact same walls/roof structure. Created in Mechanical Template and copied directly to the Construction Template. The big X is the Space Reference. Spaces have exactly same properties. Is there another setting I know know about or something? (Note: Architectural & Structural Templates are working the same as Constuction: IE Spaces only working right when start with Mech Template.) BTW: Revit 2014.
