dear all
i posted this problem in API but no answer, seems there are not alot of visitors there
i have an drawing on MEP
when i open it it takes time to load, but my main problem when i zoon in, suddenly it freezes and the loading bar at the bottom starts to move slowly 19% 22% then freezes for a min or 2 then work, and it is very slow from that moment
i opened the Archi drawing, no problem, but it seems the MEP problem only
i dont want to Purge as am still working and i dont want to lose the items inside as i might use it
i also opend the 3 packups but still same problem
it was working great few days ago and i didnt install / update anything
can someone help me with that ?
P.S : i have 12 GB Ram so i dont think it is ram problem
but i noticed this happend today (never happend before) when i only open the MEP drawing, the ram
jumps direclty to 1 or 2 GB just when it opens, usually it take 600 MB when opening only without touching the drawing
regards
Solved by CoreyDaun. Go to Solution.
My initial suggestion is to toggle 'Hardware Acceleration' under Options. Aside from that, perhaps this is an issue regarding your Graphics Card and a possible update.
You can also try with opening the worksets which are required only.
Also, till you are not performing any calcuation in Revit, uncheck the "Run Calculation for Loads in space' in Electrical Settings and can also use 'Area Only' for Volume calculation in Rooms and Area Compuation.
