Revit MEP
tsouza
Message 1 of 5 (359 Views)
Slope roof with vertical (level) equipment
359 Views, 4 Replies
10-29-2007 12:20 PM
How do I create a roof hosted family where the bottom matches the slope of the roof and top is level. Such a roof curb or platform. Or a flashing for a pipe thru a sloped roof?
I've tried locking the lower reference plan to the top of the roof and keeping selecting "always vertical" but it still makes the bottom piece horizontal.
*Matt Brooks
Message 2 of 5 (359 Views)
Re: Slope roof with vertical (level) equipment
04-03-2008 05:31 PM in reply to: tsouza
Great question... I'm trying to do the same thing. Is there a way to model a
roof curb so that it displays correctly (in section view, for example).
Thanks in advance.
Matt
wrote in message news:5763540@discussion.autodesk.com...
horizontal.
Employee
KyleB_Autodesk
Message 3 of 5 (359 Views)
04-04-2008 07:47 AM in reply to: tsouza
Are you working in the Architect's file? If so, you could do a Roof-Hosted family. Otherwise I would recommend that you create a Face-Hosted Family so it works through Linked files.
Here's what I think you could do to solve this:
* Create a Reference Plane to define the top of the curb. Be able to adjust it's angle relative to the Host Geometry via a parameter.
* I would create an extrusion that represents the Outside of the curb. Have its Profile be the side profile between the Host Geometry and the Top Reference Plane.
* Create a second Void extrusion to cut out the inside of the Roof Curb.
I'm not sure that you could make it automatically match the roof slope, but a quick dimension of the roof in the model will provide you the actual slope.
There is a lot more detailed steps to accomplish this, but bullets here really aren't going to paint the picture. I think this is a good one for my blog.
Cheers,
Kyle B
Revit MEP Product Manager
http://inside-the-system.typepad.com
Kyle Bernhardt
Product Line Manager
Revit Services
Autodesk, Inc.
Employee
KyleB_Autodesk
Message 4 of 5 (359 Views)
04-04-2008 11:26 AM in reply to: tsouza
Okay, so it was a bit more difficult. I just messed around a bit and got the result. The key was using Reference Lines rather than Reference Planes.
I'll put the creation of this family onto my "blog posts to-do" list. In the interim, I've attached the family. It only slopes in one direction right now, and you need to manually define the angle of the roof.
I'd just do a quick dimension on a section of the roof to understand the slope, and then manually modify the angle value on the curb. works nicely, I think I'll try and get this into our catalog.
Cheers,
Kyle B
Kyle Bernhardt
Revit Services
Autodesk, Inc.
Valued Contributor
N_nmulder
Message 5 of 5 (175 Views)
09-20-2013 08:44 AM in reply to: KyleB_Autodesk
So I am going to try to resurrect a really old post. Kyle, thanks for the roof curb family. Before I attempt to do so, I am wondering if you think it is possible to change the ref level (or hosting workplane) of the family to the sloped side of the curb? Or would it be better to pursue adaptive components now that they are available since you first created this family.
I think it would be a simpler and more user friendly approach for my designers to just be able to place the curb either on a sloped workplane or on the face of the roof (utilizing adaptive components) rather than creating a horizontal workplane for each piece of equipment on a roof.
Thanks in advance.
Nathan
Announcements
Need installation help?
