Trying to create a single phase panel schedule for a residential project. Even thought I have selected the 'Single Phase Panel - 120V MCB' and the properties shows 1 for the number of phases, the panel schedule still shows three phases. Any help would be appreciated. Thank you.
Eric,
See attached. I am able to adjust the first spare to be 2 poles, but the one below, no matter what location it is will not keep the 2 pole setting.
The panel is set to 42 1# pole breakers.
Thanks for the help!
Casey
Casey,
I have not been able to reproduce your issue. I attached a screen shot of what I tried. Is it possible to reproduce this in a new file and attach it? Or you can email it to me - eric dot grey at autodesk dot com. Or there may be a better way to share the file.
Eric
+1 that this is an issue. I have gotten so used to 'working around' the issue (using Revit panel schedules since release 2012) that when I was helping a new user today I realized again how confusing it is. And making fixed number templates can get tedious quick. I hope this is addressed in the next release.
hi,
i have 1-phase panel board as family but in schedule templates i didn't have 1-phase template , so how can i create 1-phase schedule template ?
i thought that the template has this option to change from 3-phase to 1-phase but when the family is 1-phase panel but actuall
when i created the schedule it is still 3-phase.
how can i edit or create 1-phase schedule
Can you clarify a little bit; are you referring to a single-phase/two-pole panel or a single-phase/single-pole panel?
The former is an American standard and, as such, is supported by Revit. The latter is not supported, and a work-around is required. The option that is presented here is to use a distribution panel schedule instead of a branch panel schedule.
Take a peek at this thread for more information: Single pole - single phase panel schedule
i used panel scheule 120/240v single phase and it was work for me but now they require panel single phase 120/208v but when i run the panel schedule as 120/208v it appear as 3 phase (A,B,C) i need the schedule to be (A&B) without C , could you help me please
Under the Panel Template's options, I believe that there is a setting to hide the third phase for such panels (I don't have Revit open at the moment to verify).
Support for single phase, line-to-neutral panels was added in Revit 2021. If there are outstanding issues, gaps, or other related improvements, please submit new Ideas.
