Our office uses a different symbol for valves than what comes standard with revit. How would I change it so that the symbol that displays in the medium detail view is something that I specify?
Solved by L.Maas. Go to Solution.
If you mean the symbol that is part of the family? Then you would have to modify the valve families and add/modify it in there.
Inside many of the valve families there are lines to represent the valve symbol.
You can modify thes to your own representation
Louis
Please mention Revit version, especially when uploading Revit files.
