Revit MEP Forum
Shifting extrusions created with EQ
1 REPLY 1
ceaves
265 Views, 1 Reply
I’ve created this family that is mounted on two channel skid extrusions. I used the EQ command on them. I’ve tried making them separately, copied and mirrored, but I end up with the same problem.
When I load the family they shift on SOME of the types, mostly the larger ones. I can’t figure out why.
Thanks in advance for your help!
1 REPLY 1
CoreyDaun
in reply to: ceaves
Edit the extrusion for the skids, delete and recreate the dimensional constraints for the skid widths (4"), and then select them and click the lock icon to constrain them to that width.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Rail Community
