Revit MEP Forum
Sheet X of Y how to?
2 REPLIES 2
revitworkbench
843 Views, 2 Replies
Does anyone remember how to automatically call out on your sheet template which sheet number it is of the whole? ie Sheet X of Y? (fill in (parameter) for X and Y?) Thanks!
2 REPLIES 2
CoreyDaun
in reply to: revitworkbench
I don't believe that's at all possible to do automatically. Revit wouldn't be able to automatically know in what order a particular user wants his sheets.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Thank you for your post.  In this case there is nothing currently automatic about this feature.  You could create a blank text field in the titleblock family, which you could then enter in information desired manually.  This would be a little more involved than what you look to be seeking.  I hope this helps.  Thank you.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
