Revit MEP Forum
Setting U values for windows?
4 REPLIES 4
3372 Views, 4 Replies
Hi, does anyone know if it's possible to define specific U values for windows?
4 REPLIES 4
abulla
You can change the "Analytic Construction" in the type properties of the window that will change the u-value accordingly. I seem to recall there being a way to add a custom u-value by editing the .txt file, but I'm not sure if that method actually worked.
in reply to: abulla
Thanks, abulla. But what if I need to be more specific, because there is nothing that's really close to the U value I need in that list....
abulla
You should be able to add custom u-values by editing the Constructions.xml file located here:
C:\Program Files\Autodesk\Revit 2014\en-US
I don't have a lot of experience editing XML files, but it looks like you can just copy/paste a section and change the u-value.
in reply to: abulla
Does anyone know where that file went?
It seems to be missing in the latest 2018 build...
...and actually now I cant see it in the 2017 folder either...
J
