Revit MEP
Revit MEP
Valued Contributor
tim102289
Message 1 of 4 (320 Views)
Accepted Solution
Setting Mark for VAV Boxes/Terminal Units to A Number + Room Number
320 Views, 3 Replies
08-27-2013 12:21 PM
Is there a way to set the Mark on a terminal unit to be a number, dash, then the room number?  Or even more specifically, A number from parameter concatenated with the room number the terminal unit is in?  If not, another option would be a column in a schedule which concatenates this information, the number in one column, and the room number in another column.
- Tim Smith
Motz Engineering
Revit MEP/AutoCAD/Sketchup
UC Architectural Engineering c/o 2016
"There is nothing more expensive than hiring cheap engineers." - Bob Sheeran, Xavier University 01/05/2005
Unfortunately, there's just no way to combine the data from fields into one, or even to add a static prefix or suffix.
*Expert Elite*
CADastrophe
Message 2 of 4 (280 Views)
Re: Setting Mark for VAV Boxes/Terminal Units to A Number + Room Number
08-28-2013 09:13 AM in reply to: tim102289
No. The Mark Value is a unique system Parameter that is not accessible for manipulation by the user. I would recommend NOT relying on the Mark parameter for identifying equipment. For more information on this, search this forum for previous discussions. Here is the latest similar thread that I know of: How to lock a prefix on a mark per family
Regarding their use in schedules, your only option would be to display these values is separate columns in a Schedule - it is not possible to concatenate parameter values at this time.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Contributor
tim102289
Message 3 of 4 (250 Views)
08-29-2013 01:03 PM in reply to: tim102289
Would there be a way to make a column in the schedule that has 4-room_number (4-01 for example)?  I think I could make labels for the floor plans easy enough but it would be nice if this was something I could put in a schedule too, without manually typing them all in.
- Tim Smith
Motz Engineering
*Expert Elite*
CADastrophe
Message 4 of 4 (245 Views)
08-29-2013 01:26 PM in reply to: tim102289
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
