Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
Did you mean:Ā
Setting Mark for VAV Boxes/Terminal Units to A Number + Room Number
3 REPLIES 3
tim102289
591 Views, 3 Replies
Is there a way to set the Mark on a terminal unit to be a number, dash, then the room number?  Or even more specifically, A number from parameter concatenated with the room number the terminal unit is in?  If not, another option would be a column in a schedule which concatenates this information, the number in one column, and the room number in another column.
Tim Smith
IT Manager, Mechanical Engineer  |  Motz Engineering
ā€œThere is nothing more expensive than hiring cheap engineers.ā€
Experienced in Revit MEP/AutoCAD/Sketchup | Autodesk BPA Certificate
3 REPLIES 3
CoreyDaun
in reply to: tim102289
No. The Mark Value is a unique system Parameter that is not accessible for manipulation by the user. I would recommend NOT relying on the Mark parameter for identifying equipment. For more information on this, search this forum for previous discussions. Here is the latest similar thread that I know of: How to lock a prefix on a mark per family
Regarding their use in schedules, your only option would be to display these values is separate columns in a Schedule - it is not possible to concatenate parameter values at this time.
ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€
āž|āž Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
tim102289
Would there be a way to make a column in the schedule that has 4-room_number (4-01 for example)?  I think I could make labels for the floor plans easy enough but it would be nice if this was something I could put in a schedule too, without manually typing them all in.
Tim Smith
CoreyDaun
Unfortunately, there's just no way to combine the data from fields into one, or even to add a static prefix or suffix.
