Hey all,
Im new here and ill admit I know very little about Revit.
Anyway, here is one of my thousand questions.
So I am drawing piping systems in Revit. I understand how to change the properties and color of a piping system. But, when I plot it, it plots in the color that I set the system in. (Or grey since im printing using a black and white plotter)
But, I want the colored system to print in black. Is there anyway to have these piping systems plot as a black line and still keep the colored visibility within Revit? Or do I have to have all these different systems in the shade that I want them plotted?
Thank you in advance for your help!
Solved by russellvee. Go to Solution.
Under the print-->setup menu you can select black lines instead of color. That is the easy way to do it as long as you don't want anything to be in color.
