I am having trouble with the routing preferences. How do I get wyes to show up for the dwv pipe type. In the junction type there is only tees. In the prefered junction type there is no wye option only tee and tap.
Solved by bvm76. Go to Solution.
edit the family and make sure that the part type assigned is tee instead of wye (see attached). after changing the type, load into your project. this should now come out from the tee list.
i am not sure that if what i am trying to do matches your explanation. i want to change the routing preferences on the pipe itself to include both tees and wyes. maybe this is not possible and i have to put wyes in manually. see attached i am not sure which family you want me to modify.
