After months of searching this issue, am I to really accept that NO ONE within AUTODESK knows how to fix or even walkthrough the "flow direction mismatch" issue everyone is having?
This has got to be a joke... Someone within Autodesk has programmed this section of code to handle the assembly and connection of pipes and their systems. Someone should understand where the problem lies and how to fix it. Why has there not been a solution posted by Autodesk Revit...?
If there is someone out there who truely understands what is going on, and will NOT just point me to some irrelevant webpage, I would greatly appreciate it if they could type a few words explaining how this error comes about.
A few questions to answer would be:
1. How does the flow direction get set?
2. Do fittings and the actual pipe conflict with the flow direction, or does the direction solely depend on the equipment connectors?
There are many other questions, but I don't have enough time to type it all out. Any insight (as always) would be greatly appreciated.
Truly,
Wils02
Let's start with flow direction - it's not as smart as you might think.
Normally "flow" gets assigned in the direction a pipe is drawn. If you use the auto layout tools, the flow is started at the selected equipment and moves to the target families. This also applies for ductwork.
I wrote an article about this in January 2013 that might be helpful - while it applies to ductwork, the same principles apply to pipe. Check it out and let me know what you think. Here's the link: http://mep-cad.blogspot.com/2013/01/getting-in-flow-with-revit-hvac.html
PS - your later link on deleting the system is novel, hadn't seen that soluton before - nicely done!
Let me know if this helps - db
David A. Butts
Engineering Technology Manager - Gannett Fleming
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
Thanks David for the reply. I actually have referenced your site many times, its one of the better written ones out there. I was quite frustrated at the level of mystery behind piping system at the time, but since I wrote that "How To:" I have been doing much better.
Again thanks for the reply!
Sincerely,
Jared
