Hai...
i prepared a pump with 4 connections
see attached snapshots
one side the connections are near to the equipment
the other side the connections are showing very far from equipment
i dont know whats wrong.
see the second snapshot which shows the connector so far from equipment...
some time it makes big problem in the model..
clarify me
thanks.....
to have a better understanding of what is going on to your model, i would suggest you to upload it so the community can check.
i cannot reproduce the issue you're looking at. as i can see all connectors are all in place (se attached)
it looks like you did not realized that the one i attached in my previous post is actually loaded in a sample project with connected pipes. It shows that when I clicked the booster set (highlighted) all the connectors are in the right place!
