Revit MEP Forum
Selection of type fittings and joints
1 REPLY 1
marco.defina
168 Views, 1 Reply
i have 2 questions...
1. Sometimes i need to have connection between pipe with Tee and sometimes with a branch.
I created 2 type of Pipe with a different preference for the branch. One with Tee and one with welded joint. This why i've seen that i can't insert the  2 type of connection in the same preference.
Is the right way???
2.When i connect 2 pipe i will have the possibility to select wich Tee to use between the 3 i have in the preference during the connection, not after. It's possible?
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
1 REPLY 1
marco.defina
in reply to: marco.defina
up...
