Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Select by Comments?
1 REPLY 1
revitworkbench
2791 Views, 1 Reply
Select by Comments?
Is there a way to select a group of items in a view by comments or type mark?  Thanks!
1 REPLY 1
CoreyDaun
in reply to: revitworkbench
Well, you can use a Schedule to select all elements based on the Comments value but you cannot, however, then narrow it down to the elements that appear in a specific View. You can create a View Filter to hide all of the other elements in that View, i.e. "Comments" does not equal [Value]. That way, it a matter of hitting V/G and unchecking the box to isolate those elements.
That's the best method I can think of at the moment, unless these elements also belong to a separate Workset.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
