Revit MEP
michaelmead
Message 1 of 2 (202 Views)
Select by Comments?
202 Views, 1 Replies
02-13-2013 10:48 AM
Is there a way to select a group of items in a view by comments or type mark?  Thanks!
Well, you can use a Schedule to select all elements based on the Comments value but you cannot, however, then narrow it down to the elements that appear in a specific View. You can create a View Filter to hide all of the other elements in that View, i.e. "Comments" does not equal [Value]. That way, it a matter of hitting V/G and unchecking the box to isolate those elements.
That's the best method I can think of at the moment, unless these elements also belong to a separate Workset.
CADastrophe
Message 2 of 2 (194 Views)
Re: Select by Comments?
02-13-2013 12:23 PM in reply to: michaelmead
