Just downloaded the Revit 2015 trial, installed it, and now, after logging in with Autodesk User ID, this is the result:
What the hell do I do????
This is likely a problem with your Internet Explorer. What version are you running and is it your default browser?
Other people are reporting the same issue also, so it is possible that the problem could be on the website.
Edit: I am going to try to escalate this.
Any updates on this fix?
You were correct in your initial assessment. I have Chrome as my browser. I changed the default to IE, and it worked just fine.
Thanks!!
I have received notification and confirmation from other users that this is now fixed. I have been trying to hit all the threads about this. Try it now and let us know. Thanks!
