I have a Plumbing Fixture with nested families (Toilet, Flush valve, Seat, Carrier) and I want to Schedule these with the Toilet having the "Tag", and the other objects being called out under the Toilet. Is this possible?
I think it is possible if each item you are trying to schedule is its own family all loaded into one family with each family having the shared box checked under Categories and Parameters prior to loading it into the final family, I think that makes sense.
Yeah, I can see each item individually scheduled. I just want the nested items to show as different fields behind the main fixture. I think I found a way, I Created Shared "Family" Parameters for Seat, Flush Valve, and Carrier, associated each with the Shared Parameter. They showed up properly in the schedule.
