Revit MEP Forum
Schedule items per floor
2 REPLIES 2
1720 Views, 2 Replies
I have a building with Ground, first and second floors, each containing a number of light fittings.
How would I produce a schedule for each floor?
Is there a way to select objects to schedule, or does revit schedule all items in the project?
2 REPLIES 2
russellvee
Include the 'Level' field in your light fixture schedule, then under Sorting/Grouping choose sort by: level.
You can use the filter options to remove specific items from the schedule. For instance, filter for: Type Mark != 'blank'. Then set the Type Mark to 'blank' on all the fixtures you don't want to schedule.
in reply to: russellvee
Thankyou
I added the Levels to my schedules and then filtered by level as you suggested and all now working fine,
