Is there a way to create a schedule in revit of only selected items? There was a change directive in one of my projects and I want to only schedule the additions due to the change directive, but they consist of many categories and even levels. Thanks.
Solved by CoreyDaun. Go to Solution.
As long as there is some means of differentiating those elements, such as a Parameter value. You can use the Filter tab within the Schedule Views Properties to define the criteria by which elements are included/excluded.
If you wish to list elements from multiple Categories, you can do so by creating a Multi-Category Schedule. However, the available Fields to pick from are vastly more limited than Category-specific schedules.
Yeah, but not just to be able to select the things you want, and schedule them? Its tedious to go back and try to modify everything so that it is different in some way.
There has to be an logical foundation to an "I want this" statement in order for Revit to obey, so having something like specific rooms in which all of the elements should be scheduled would be good. If the elements are scattered, you're best bet may be to place an "X" under the Comments field for those particular elements.
Right, I understand that. I was just hoping that having things selected (highlighted) would be enough logic for revit to schedule them. Like if you highlight a bunch of random stuff, you can hit the delete button and it goes away. In my opinion there should be a schedule selected button (or option)
I get what you're talking about - I've wished I had such a thing so I could quickly estimate electrical loads among devices before committing to the arduous task of assigning them to circuits. Anyway, the closest you're going to come to that is what I mentioned previously: select the elements and add a value to the Comments Parameter to all of them at once, and then create a Schedule that Filters out anything that doesn't have "X" for Comments. That pretty much accomplishes the same thing.
It doesn't work for nested families. I'm using families composed by commercial components already assembled.
I need to count the commercial families nested inside the hosts families. If I modify the Comments parameter, this will modify only the host families and not the nested.. Have I been clear?
Those nested component Families would have to be marked as "Shared", which is accessible in the Family Editor under the Family Category and Parameters dialog. Here is a (hopefully) helpful entry from Revit Help:
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-377AA649-AE44-4F1E-A588-1C9590D005F4
You should be able to TAB+Select the nested, shared families individually and access their properties that way. Using CTRL to add elements in conjunction with TAB to cycle through nested elements is a little tedious, but it'll work.
If you don't want to have to do this, you can open the host family in the Family Editor, select the nested Family, and link the desired parameter to a parameter in the host family (you will likely have to create a new Shared, Instance Parameter for this task). For example, you can select three nested components in a family and under properties, you can click the grey button on the right of the custom parameter and link it to the same custom parameter in the host (via the following dialog). In the project environment, if you then enter a value for this parameter for the element and the value will automatically be applied to the nested families as well.
You can link a instance parameter of the nested families to a parameter of the same type from the host.
In this case the nested family will get the value from the host component.
Fábio Sato
I know + TAB select .. but for Hundreds of families it's too much effort ..
