Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Rounding off values in schedules and tags performing calaculations
5 REPLIES 5
1146 Views, 5 Replies
Two part question
1. In a schedule what needs to be done to show say 350.0 as 350? No decimal
just rounding off up or down.
2. When placing a room, space or area tag, can one of the values perform a
calculation, or pull from a value parameter or other and have it show up in
the tag. An example would be: using the area for the room and multiply it by
2.5 and place that value.
5 REPLIES 5
Two part question
{color:#ff0000}under the properties of the schedule go to the formatting tab
highlight the parameter you need to be rounded
click field format
uncheck the use project units then you can change the decimal place{color}
{color:#ff0000}a shared parameter would need to be created and added to the part your trying to do this for. the parameter would then be a formula multiplying the 2 other parameter. when you create that shared parameter make sure that the unit type matches what would be created by multiplying the 2 other parameters. if thats not clear enough let me know{color}
Thanks i'll try that
Two
part question
down.
the formatting tab
rounded
click field format
calculation, or
the tag.
Did you ever get your second problem to work? I am running into this as we speak. I've tried everything under the sun, and the only help I've gotten is to use BIM Link. There has to be another way. Thanks.
CoreyDaun
Hi wyankey, welcome to the Discussion Groups!
The Labels that reside in a Tag are only capable of reporting the value of a given parameter that belongs to the tagged element, so  the Tag is not capable of housing any calculations. The best you could do would be to create a Shared Parameter and target that with the Tag, but unfortunately, Shared Parameter cannot include formulas or calculations either, which required manual input.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Thanks for the info. This is exactly what I was afraid of.  I've been doing far too much research this morning to come up with a dead end.
