Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Rotating Title Block Revision Schedules: Is this possible?
1 REPLY 1
davebillion
1608 Views, 1 Reply
We're finally getting into Revit and want to get the most out of the tools built into the program.
Our current standard title block has the revision data turned 90 degrees so that it's readable from the edge, along with most of our border data.
We like the idea of having revisions numbered by sheet, so we want to use the built-in revision schedule.  Problem is, we can't rotate it to go with the way we've done things.
Or, can we?  Is there a method for rotating the revision schedule?
Thank you.
Dave.
1 REPLY 1
CoreyDaun
in reply to: davebillion
In the Title Block Family, if you select the Schedule Graphics, a pull-down should appear on the Options Bar (just below the Ribbon) which will allow you to specify a rotation.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
