Revit MEP Forum
Rotating Title Block Revision Schedules: Is this possible?
1 REPLY 1
1609 Views, 1 Reply
We're finally getting into Revit and want to get the most out of the tools built into the program.
Our current standard title block has the revision data turned 90 degrees so that it's readable from the edge, along with most of our border data.
We like the idea of having revisions numbered by sheet, so we want to use the built-in revision schedule.  Problem is, we can't rotate it to go with the way we've done things.
Or, can we?  Is there a method for rotating the revision schedule?
Thank you.
Dave.
1 REPLY 1
CoreyDaun
In the Title Block Family, if you select the Schedule Graphics, a pull-down should appear on the Options Bar (just below the Ribbon) which will allow you to specify a rotation.
