Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
rotating massing
2 REPLIES 2
596 Views, 2 Replies
rotating massing
Testing out the New Conceptual Energy analysis and creating the mass, what will be the best way for rotating the massing in 45 or 90 degree?
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=15794705
thanks,
Kevin
2 REPLIES 2
scott_d_davis
When editing the mass, you can choose the rotate tool and rotate the mass 45 or 90 degrees.  You may also want to consider placing a rotation parameter that would allow you to change the mass by simply plugging in a new number.
Scott D Davis
Sr AEC Technical Specialist
in reply to: scott_d_davis
Great; and can you show me how to setup a rotation parameter?
