Revit MEP Forum
Rotating Linked CAD file
3 REPLIES 3
6188 Views, 3 Replies
Hi Guys,
What I am trying to achieve is simply getting linked CAD file to rotate as soon as I import it to REVIT.
I tried all different options with rotating true North and project North and orienting the views.
The linked file rotates but as soon as the Revit model gets reopened the linked CAD file rotates back to it's original location!
I don't want to cheat and rotate the CAD file before importing to Revit.
Have also had a look on
http://forums.autodesk.com/t5/Revit-Architecture/Linked-CAD-keeps-rotating/td-p/3491164
and
http://autodesk-revit.blogspot.co.uk/2007/09/shared-coordinates-true-north-project.html
but didn't really help
Could someone please let me know how it can be done properly?
3 REPLIES 3
CoreyDaun
I have two immediate tests to suggest: try Pinning the CAD Link and then try linking it from your local drive (I assume the original is on a network location) and see if the problem persists. This isn't intended to be a solution; just a means of isolating the cause.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
brilliant Corey.... after pining the CAD link the issue is resolved...I also tried reloading the file and it captured all the changes in the model without rotating it back to the 1st place... it's great to have you in this forum 😉
Zsolt.Varga
Hi guys,
I just saw your conversation - maybe just an additional comment pointing you to the information in this article. (might be useful avoiding confusion):
http://knowledge.autodesk.com/article/Revit-DWG-link-rotates-when-reloaded
Best regards,
Zsolt Varga
Technical Support Specialist
Autodesk, Inc.
Revit Ideas | Screencast | Revit Help | AKN
