Revit MEP Forum
rotating an inported ADSK massl
6 REPLIES 6
stevenson53
368 Views, 6 Replies
There there,
Does anyone know how to rotate this ADSK model please?
It says I can't rotate a pinned element.
I set a plane and tried to rotate that but it only rotated the plane and not the model.
See attached.
Paul
6 REPLIES 6
L.Maas
in reply to: stevenson53
When I open the Floor Plans Level 1 view and select it I see
In the middle you see the pin (normally when importing links they are automatically pinned). When you click on that pin it will become free to rotate.
Louis
Please mention Revit version, especially when uploading Revit files.
stevenson53
in reply to: L.Maas
Great job thanks for that!
Can I also ask you about the attached please.  This is another imported ADSk mass and it has these funny curved lines coming away from the block.
Any thoughts please?
Paul
L.Maas
You mention another...but it is the same family? wrong attachment?
I do not see 'funny' curves  or are you talking about the grid you see on the screenshot?
Some of the lines you see there are the workplane that is shown by the selection in hte ribbon.
And in between you see some of the reference planes.
Louis
stevenson53
in reply to: L.Maas
So sorry, I hit the wrong button!  here is the right file.
Paul
L.Maas
It seems the import is a 'complex' model. Revit seems to have problems to (re)create the model. It seems to be an edge from a saddle type connection. Due to the problem the lines go haywire. So it would be better to recreate it in Revit or simplify the model in its source program.
Louis
stevenson53
in reply to: L.Maas
Thankyou, I appreciate the prompt help!
