I'm having a few problems rotating assemblies. The attached 2015 file has an assembly that I would like to rotate. I believe it has something to do with the Puddle Flange family being hosted but I'm not sure how to fix it. Thanks.
Solved by L.Maas. Go to Solution.
Hugh,
Best way is to study available families. If you check your libraries, under pipe fittings, you will probably find some flanges.
When you check them you will see that the connectors are along the "x-axis" (ref level), not on the y-axis like your puddle flange family.
Correcting this issue will probably solve your issues (if not let me know and I will check your family in more detail).
Further notice that they use the pipe fitting category, which is commonly used for these type of items.
Louis
Please mention Revit version, especially when uploading Revit files.
