Solved by CoreyDaun. Go to Solution.
Rooms are typically created by the Architectural team, whereas Spaces are used by the MEP team. When working with a linked architectural model, one must first select the linked model, go to Type Properties, and enable the option "Room Bounding". The placement of Spaces is supposed to correspond to the location of the Rooms. Once placed, the Space will associate with the Room and pull information from it.
As long as the elements are located within a Room, the Mechanical Equipment and Air Terminals categories should be reporting their Room information. Ducts, Pipes, and Fittings (and other similar MEP elements) will only become associated with Spaces.
For more information on the specific use of Spaces, see >>here<<.
