Revit MEP
michaelmead
Message 1 of 2 (249 Views)
Room association
249 Views, 1 Replies
08-30-2013 04:03 PM
Hi, I am having trouble associating my system equipment, ducts, or diffusers with my room's. To begin with, I created my rooms are 2-D plan view, then I went to a section view to increase the height of the rooms to include the ductwork in the and the vavs. However nothing is associating with that room, at all. Am I supposed to use spaces? I don't really understand what spaces are. Please help! Thank you!
Rooms are typically created by the Architectural team, whereas Spaces are used by the MEP team. When working with a linked architectural model, one must first select the linked model, go to Type Properties, and enable the option "Room Bounding". The placement of Spaces is supposed to correspond to the location of the Rooms. Once placed, the Space will associate with the Room and pull information from it.
As long as the elements are located within a Room, the Mechanical Equipment and Air Terminals categories should be reporting their Room information. Ducts, Pipes, and Fittings (and other similar MEP elements) will only become associated with Spaces.
For more information on the specific use of Spaces, see >>here<<.
CADastrophe
Message 2 of 2 (172 Views)
Re: Room association
09-03-2013 05:34 AM in reply to: michaelmead
