Revit MEP
Valued Mentor
julianjameson8403
Message 1 of 3 (724 Views)
RME 2012 - Filtering Piping systems using Type Comments
724 Views, 2 Replies
09-24-2012 09:43 AM
Hi all
Anyone know if this is possible and how to get it to work? I have set up Piping systems using this parameter to group the various systems onto documentation views - i.e MECH-GAS would be used to isolate gas pipework in a documentation view. I then combine this filter with another one that turns off any piping system that does not contain MECH in the Type Comments. I have tried different categories ranging from all piping categories to just Piping Systems.
Unfortunately this method doesn't seem to work. Anyone got any ideas where I am going wrong or if it is possible?
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
I see what what mean, and that doesn't seem to want to work. Since the Piping Systems isn't really a visible Element, turning it off seems to do no good. Would you be able to add a "key" to the System Name for the View Filter to find? (i.e. "(MG)" suffix for Mechanical Gas)
CADastrophe
Message 2 of 3 (715 Views)
Re: RME 2012 - Filtering Piping systems using Type Comments
09-24-2012 11:13 AM in reply to: julianjameson8403
Valued Mentor
julianjameson8403
Message 3 of 3 (707 Views)
09-24-2012 12:32 PM in reply to: CADastrophe
Ha ha - I had a feeling you would be the first to comment.
I used to filter by system parameters within piping or duct systems, such as using the system name or classification, etc. but wanted to try avoid this and produce a template that had more control than normal and not rely on users naming systems in a way to get filters to work (especially as the filters are very sensitive). I was trying to set something up so new user get on a design/model and the template automatically controls the displays.
I thought (stupidly) that a simple yet effective way would be to use a Type Comment parameter as it doesn't get used for anything really. That way I could free up description and abbreviation as the basis for company tagging of system names/abbreviations.
Perhaps I'm thinking too hard about getting the template to work better for me. Anyway, if ADSK could get this to work then I'm sure it would be a very useful tool.
In the meantime, looks like I have to take a step backwards to the old way or as you say - add an un-necessary project parameter to get this to work
Thank you!
