Revit MEP
Valued Contributor
lsop1409
Message 1 of 2 (185 Views)
Revit to use modified families automatically
185 Views, 1 Replies
11-27-2012 02:01 AM
Hi
I have modified the OOTB square to round fitting by simply deleting the flange from the round end, as it is not required. Question is, how do I get Revit to automatically use this modified fitting instead of the original one, so that I don't have to manually exchange fittings after they have been automatically drawn.
CADastrophe
Message 2 of 2 (176 Views)
Re: Revit to use modified families automatically
11-27-2012 05:47 AM in reply to: lsop1409
The default fittings to be used are defined under Type Properties for each Duct Type. This applies to Pipe, Conduit, and Cable Tray as well.
