Revit MEP Forum
Revit to use modified families automatically
1 REPLY 1
344 Views, 1 Reply
Hi
I have modified the OOTB square to round fitting by simply deleting the flange from the round end, as it is not required. Question is, how do I get Revit to automatically use this modified fitting instead of the original one, so that I don't have to manually exchange fittings after they have been automatically drawn.
1 REPLY 1
CoreyDaun
The default fittings to be used are defined under Type Properties for each Duct Type. This applies to Pipe, Conduit, and Cable Tray as well.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
