Revit MEP Forum
Revit Slowdown
2 REPLIES 2
388 Views, 2 Replies
Revit Slowdown
Recently we finished a very large project. As the model grew in size the drafting of the HVAC slowed down termendously. It was so slow that connecting flex to  a grille took 4 seconds and deleteing something to 4-5 seconds. It added up over time.
I realize the file got big and I was told to reboot Revit do to its cache system. I did that everyday at lunch and it help a little.
My question: Are there any tips or tricks to make the drafting operate faster as the file grow? Any settings or hidden buttons I can click?
2 REPLIES 2
CoreyDaun
Check Manage tab » Warnings. A staggering amount of warning can bog the project down. There have been posts addressing this issue in recent history, and I would suggest searching this forum for those threads.
Sandleaz
That problem could have been avoided completely if your mechanical revit users started with multiple smaller, more manageable REVIT files instead of 1 file.  It's easy linking the files together.  It's hard working in a giant slow file.  The convenience of having one file will wear off as it gets larger and larger and REVIT runs slower and slower.  The trade off is simple: (A) short term convenience + major problems later on vs. (B) some adjusting and more setting up early on + no problems later on.  I choose (B) every time.
Suggestion: turn off all the pipe and duct flow and pressure calculations.
